F450 ARF Question
F450 ARF Question e300 Power Hub missing?
I recently received a new F450 ARF kit, this weekend I started laying out pieces and came across something I question. The kit comes with the e300 ESC's, but doesn't come with the power hub that the e300 propulsion kit appears to come from in various videos I've seen.
The problem is, that the wiring on the e300s doesn't fit the F450 board, so, should I simply add some extra wiring to make these work, or, should I have received the Hub along with all the other parts in the ARF kit? I haven't reached out to the vendor I purchased the kit from, figured I would ask here first to see if anyone else had any experience with this kit before doing so.
Chris
I ended up emailing/heading back from the Vendor. They said that the ARF doesn't come with the power hub, so to just solder to the base plate. I'll go down that path this week unless someone else suggests otherwise.
peel back some of the metal shielding and twirl it together. From there you have enough space to solder directly to the board of your F450 :D
