XAircraft EZUHF connection with SuperX
traxx2003
Hello everyone, I was wondering if someone could help me figuring out how to connect the SuperX with an EZUHF receiver. I know that the SuperX with the I/O unit V2 is now SBUS compatible. The EZUHF receiver also supports SBUS thru channel 1, as long as you set CH 1 to Muxed. But when I connect and power the system, all Im getting is a red flashing light from the SuperX, indicating that the RC connection is not present. Can someone explain how I should connect the SUPERX to the EZUHF system?
Thank you!!
traxx2003
Sure did, i had to connect all servo wires. For some reason, even dough both of them are SBus compatible, they will not work with SBus together. I believe is because SuperX uses PWM signal and EZUHF uses PPM. But don't quote me on it. But is you use one servo wire per servo, it works just fine.
