Hello all, I am VERY frustrated with my build.
Hovership ESC - http://shop.hovership.com/h-12a-esc-2-4s/
Hovership Motor - http://shop.hovership.com/h2204x-230...ceted_search=0
Naze 32 Acro
Hovership PDB
I have soldered all of my leads down, I plug my USB cable into my Naze32 and go to "motor testing" I raise the slider to max, and insert my battery. My esc's will beep, but when I reduce the slider to min they do not make any noise & the motors do not spin afterwards. I thought it could be my PDB soldering.. so I wired a spare XT60 lead (presoldered from multirotorsuperstore) to 2 of my Esc's, and again the same problem. The motors pulse & esc's beep when I put the battery in.. but thats it. They don't move when I apply throttle from the test section. I tried turning off motor arming and making min throttle 1000, max 2000 but i don't think this did anything.
I do have my radio setup (D4R-ii & Taranis x9d) but haven't even bothered plugging it in, I need to verify motor functionality which I currently cannot... Also it seems like my naze32 has my throttle on my mode 2 taranis on the right stick.. yet both are set to aetr and taranis says mode 2 on radio setup.
I could really use some help, I'm staring at $550+ worth of gear.. I can't figure it out.
Naze 32 Acro
Hovership PDB
