GotHeliRC.com Eachine Falcon 250 250MM Frame Kit with PDB Board and Tilt motor mount
GotHeliRC
http://gothelirc.com
Eachine Falcon 250 frame kit and PDB board (built in BECs) and tilt motor mount
$35.00
Description: User Manual
Thickness of Fuselage: 1.6mm
Thickness of Arms: 3.0mm
Wheelbase: 250mm
Dimension: 230 x 245 x 90mm
Take off Weigh: 535g
Net Weight: 236g
Features:
Compatible with max 6 inch propeller
Compatible with 2206,2208 motor
Can be used with 4S/3S battery
Inclined motor base design, fast speed
Removable protection motor base
Package Included:
4 x Arm
1 x Base Board
1 x Left Side Board
1 x Right Side Board
1 x Cover Board
1 x Top Damping Board
1 x Tail Board
4 x Motor Protection Base
4 x Foot Stand
4 x Damping Ball
1 x PCB
1 x Screw Pack
1 x Column Pack
Frame required assembly.
wow, $35? what's the point of the tilted motor mounts? i never figured that one out...stability? yaw control?
ProfEngr
I saw a MR race vid from across the pond on youtube where the forward tilt was only used on 1 pair. They also had different length arms between the front and rear pairs. It was explained that this improved speed/agility while reducing spin-out in turns caused my all 4 motors being tilted.
