Hello everybody. After a long time waiting, I have decided to make an All-in-One 250mm size Mini H Quad frame nicknamed the “Mini-D.” First, I would like to thank Frank aka Sinewavz (on OP forums) for his assistance with this game changing design. Here are some specs of the frame:
The “Mini D” is a Clean/Dirty plate design separated by M3 dampers so you can take jello-free videos with your HD camera. I have flown it numerous times now but have never had any jello issue…so what makes it different? Read on…
3 different thickness of G10 plates were used:
Arms - 3mm thickness and individual, so very easy to change and no need to buy an entire new plate
Dirty plate & NEW - “Belt” design consist of 1.5mm G10
Clean-1.5mm G10
Top plate - 1mm G10
As you know most of the other dirty part designs are almost identical. So I decided to make my own dirty and called it “Belt” design. This has proven to provide an amazingly strong frame while saving both a lot of weight, and allowing for a second dirty plate.
“Mini D” also includes it’s own PDB!! There are both "+" and "-" poles which make it easy to attach your choice of up to 12A ESC’s soldered direct
Adjustable CG (Center-of-Gravity) via changeable dampener positions for the clean section AND also adjustable FC (Flight Controller) positioning
Different Variables for FPV/REC camera:
1. CCD Camera can be used naked with provided camera plate w/ Mobius on top plate
2. CCD camera in metal casing mounted (3 Different position holes for Case)
3. Removable GP2/3 plate can be easily attached to front
Lipo’s used: - (Sunnysky X2204 2300kv Motors used for testing)
Zippy Compact 1300mAh – CCD & Mobius HD
Nano-Tech 1500mAh – CCD & Mobius HD
Gen Ace1800mAh – Used with GoPro3 combo (check weights for GP2)
Frame Weight –140-147 gr (with the 3mm g10arms)
YES…we love this mini and thought, “Why not make it smaller?” So we made it a 250 foldable!! just remove the thumb nuts and fold it. Travel Friendly indeed.
Rock solid & light! Here’s some users' videos and a list of equipment used, enjoy!
Clean-1.5mm G10
Top plate - 1mm G10
