Hi there guys,
I own a Dji F550. After a couple of tests, and because I was a beginner I put my throttle stick all the way down and a shut down the motors. So my F550 free fall to the ground and broke the center frame.
After that I purchase one center frame and did the soldering of all the ESC's, battery cable and gimbal. After that I start to fell much more conformable about building my own copter.
So I going to build a Tarot 690s for my Sony nex5.
I already made a nice setup and "tested" it on eCalc.
the setup is this:
Tarot 690s frame
T-Motor 2814-10 770Kv
T-Motor ESC 40Amp 400HZ
T-Motor 11x3.7 Carbon propeller
Naza M v.2+Led+PMU+GPS
3axis gimbal for Sony Nex (http://electronicarc.com/catalogo/p...=1425&osCsid=b79cf57f0c545f08a75452da433e79cf)
Graupner MZ 18 HOTT trasmiter (9 Ch)
Graupner HoTT GR-24 receiver (12 Ch)
Lipo's 4S 5000 mAh 20-30C
I think this is all i need to build and fly my drone.
I only don't know if the tarot has a power distribution hub inside like the F550.
Anyone has a clue ???
By the way what do you think about this setup???
I wiil post here some test's after put all thing together.
Thank you all
the setup is this:
Tarot 690s frame
Thank you all
