DJI WKM motor does not shut down all at once
paktazh
Has any one had this problem my WKM hexa copter motor start OK and all motor start at once but when I reduce the throttle the 3 motor on one side shut off but the other 3 on the other side still keep running . Don't they suppose to start at once and shut at once ? has any one else had this issue ? thanks
paktazh
also when i try to left off it try to flip to one side i build this some time ago but did not use it so what could be done to fix that any help ???
mbsteed
aerial video centric
Did you calibrate the ESCs for throttle high and low? You should do that before setting it up. I think with WKM you have to do each ESC separately.
