Welcome To DroneVibes
DJI Photogrammetry - anyone help me get it to work?
Discussion in 'DJI Discussion' started by dani_r, Apr 16, 2013.
  1. dani_r
    dani_r Member
    12
    0
    0
    Jan 27, 2013
    Posted by dani_r, Apr 16, 2013 #1
    Hi guys,
    I am struggling with this DJI Photogrammetry tool on my WKM.
    I have got it to the stage where we load the flight plan etc, but can't get the camera to link up properly and take the pictures where it needs to. Clearly I'm missing something.
    There isn't too much on the topic around on the net (none that I've found anyway).
    Has anyone managed to get it to work?
    My setup is PH AV200 (yeah yeah, I know...lol) on a Vulcan 1200mm Hexa with the full compliment of DJI toys. Futaba SBus connections. My camera is triggered with a Stratosnapper unit.
    Any help much appreciated :)
    Cheers
    Dani
    Tags:
  2. dani_r
    dani_r Member
    12
    0
    0
    Jan 27, 2013
    Posted by dani_r, Apr 20, 2013 #2
    Not a good sign then if not a single person can help me out here. No one has managed to get it to work then?
  3. buddyrama
    buddyrama Member
    16
    0
    0
    Jan 10, 2012
    Posted by buddyrama, Jun 28, 2013 #3
    you have to set up the servo actions to trigger the camera at a particular time or distance. look under tools. It is in the manual too.
  4. pls4air
    pls4air Member
    11
    0
    0
    Sep 20, 2013
    Posted by pls4air, Sep 20, 2013 #4
    we to are having trouble auto triggering the camera. we are using sony nex 7. I can trigger the camera manually by clicking trigger and reference photo but it will not take pictures automatically while in flight. we are using the 50 way point system. GS 4.8
    can someone help explain the settings in servo action config box?
  5. leofuica
    leofuica Member
    83
    0
    0
    Apr 22, 2013
    Posted by leofuica, Sep 21, 2013 #5
    WELL WELL WELL
    Finally i found a treasure.....point by point:
    -You need a IOSD MK2 (no WK file, is similar but don´t use it) updated IOSD MK2 to the last FW for use a file to export, only if you really take a pics in REAL or SIMULATED MISSION
    -Taked pics with WK and GP servo action ON in control of the camera, every pic is a ONE ACTION in GPSexporter.
    -You need update GS to the last version
    -You need a GPSexporter 1.2 version, the last version
    -You need a 5,26 Wookong Firmware
    Only with all of this steps you can export a usable -txt file (with GPS EXPORTER) with a info like that IF YOU FLY REALLY WITH A REAL MISSION AND TAKE PIC WITH WK:
    1 1 -70.5445244154 -33.4314905051 751.9216918945 -8.2350430486 3.7321304150 -43.1582699601
    The first number or column is a number of action or pic
    The second if is a 1= pics taked with WK if 3= pics taked with REFERENCE PHOTO or TRIGGER in GENERAL PURPOSE SERVO ACTION CONFIG.
    The third is latitude
    The fourth is longitud
    The fifthis altitude
    The sixth, seventh and eight is actitude(pitch, roll and yaw)
    The config GP servo action (in WK is F! port) for Nex 5N or 6 or 7 via infrared
    Natural Servo position: -500
    Action step 1: 500 Stay time: 0
    Action step 2: 1000 Stay time: 0
    Action step 3: 500 Stay time: 0
    Set and probe it with Trigger
    First connect the data link at the least 7 meters away from you.
    Second config the PHOTOGRAMMETRIC TOOL, insert all data in white windows (alls of them with out exeption)
    Click to draw a region with you want to scan
    Preview the result and if you satisfaction with this, GENERATE
    Before this you can probe the REFERENCE PHOTO and see if take it, a pic every 2 seconds is normal
    Generate and edit the mission, altitude, speed, etc etc
    Before you can fly the mission in SIMULATED MODE and probe, again severals times since you can fly the first mission.
    Is not easy, but with hard work you can made it.
    Actually i fly severals times and the results is very accuracy, but not VERY VERY ACCURACY.
    Note:
    Each pic taked genered a one file secuencial....
    I read all DJI`s manual and this info dosn´t exist...is funy but cruel at the same time...
    Enjoy
  6. terry.one
    terry.one New Member
    4
    0
    0
    Aug 1, 2012
    Posted by terry.one, Sep 22, 2013 #6
    Yes, Leofuica is right. Pay attention to GP servo action set up. If your servo trigger camera at 600 for example, you just set neutral as -500, Action step 1: 600, Stay time:1 ; No need to set step2 or step3.
  7. leofuica
    leofuica Member
    83
    0
    0
    Apr 22, 2013
    Posted by leofuica, Oct 10, 2013 #7
    Terry.one:
    Anyway work very good for me, if the action work in SIMULATION inthe real world too....
  8. dani_r
    dani_r Member
    12
    0
    0
    Jan 27, 2013
    Posted by dani_r, Oct 15, 2013 #8
    Ok so I've got that far. Had it simulate a mission and flown it in Simulate mode. It adds a green triangle at certain points, but does not trigger the camera. Should it trigger the camera even in simulate mode?? Or not?
  9. pls4air
    pls4air Member
    11
    0
    0
    Sep 20, 2013
    Posted by pls4air, Oct 15, 2013 #9
    It will not trigger camera in simulator mode
  10. kev333d
    kev333d Member
    6
    0
    0
    Oct 16, 2013
    Posted by kev333d, Oct 16, 2013 #10
    This forum is great, so I plan on building an f550 for doing photogrammetry. Its great to see others out there with some info, maybe you guys can help. What would you suggest I start with? Im already familiar with the F550 naza m v2, gimbals and basic photopraphy...what my main question is..what FC should I be using..the A2 or the WKM...I have read about both, but im not certain if the A2 has the photogrammetry setting like I saw with the WKM? Also whats the best camera to be using? Sorry if this is a loaded question and maybe it should be moved to its own thread.
  11. pls4air
    pls4air Member
    11
    0
    0
    Sep 20, 2013
    Posted by pls4air, Oct 16, 2013 #11
    Dont use DJI is my suggestion. The photogrammetry and geo tagging have been nothing short of a let down. We are going with another platform once we start generating money w the S800 we already have. Camera depends on what you are trying to accomplish. We are doing 3D modeling w point cloud generation. Go visit our web site Airtopo.com. If you are just using FPV w video record you cant beat the new gopro.
  12. leofuica
    leofuica Member
    83
    0
    0
    Apr 22, 2013
    Posted by leofuica, Nov 3, 2013 #12
    pls4air:
    I used sucessfull a Photogrametric DJI tools, geotagging, acctitude in each photo, altitude, latitude and longuitude every pics fine, great for work in 3D, point cloud, etc etc.
    I trigger my camera NEX 5N trough the WK (with action setting) in real and simulate mode with out problem, maybe your not follow all the instruction because the DJI manual is very strange and short, but with hard work i have all the potencial of WK GS, and beleave me, is powerfull than others like APM 2.6
  13. danproud
    danproud Member
    37
    0
    0
    Nov 29, 2011
    Posted by danproud, Nov 4, 2013 #13
    I'm having a lot of luck using an intervalometer rather than DJI triggered photos (couldn't be bothered trying to get that going!). On my S800 EVO I'm using a Canon 6D with GP-E2 for geotagging images, shooting every 2 seconds. point cloud 3D models and orthomosaics are coming out great in Agisoft Photoscan. All I need now is longer flight times... The GP-E2 also records a log file so you could geo-tag images from any camera at a later point...
    I'd be interested in more discussion about DJI gear for mapping / surveying / photogrammetry & 3D but there doesn't seem to be many people around doing it?
  14. JustinTanny
    JustinTanny Member
    27
    0
    0
    Jun 19, 2013
    Posted by JustinTanny, Nov 7, 2013 #14
    Can this be done with IOSD 1 or Just IOSD II
  15. flyingbiscuit
    flyingbiscuit Member
    78
    0
    1
    May 1, 2012
    Posted by flyingbiscuit, Nov 8, 2013 #15
    Just wonder what you are using? What was the main problem you have with geotagging images? I am not sure about the DJI geo tagging solution, or what is a better one
    any help gratefully received!
    fb
  16. leofuica
    leofuica Member
    83
    0
    0
    Apr 22, 2013
    Posted by leofuica, Dec 15, 2013 #16
    I have for geotaging a GEOSETTER, is very easy to use it and NOT NEED IOSD FILE or GPS EXPORTER FILE, you geotagging every pics in Geosetter and write values into EXIF file, Photoscan Pro read this file and voilá.....succesfull
    Enjoy too...
  17. Quinton
    Quinton Active Member
    1,037
    2
    0
    Aug 18, 2013
    Posted by Quinton, Dec 16, 2013 #17
    That is interesting, I take it the 6Ds built in GPS function is not good enough?
    What were you using as a intervalometer, pity it also needs the latest firmware otherwise you could have used Magic Lanterns'.
  18. spider73
    spider73 New Member
    1
    0
    0
    Sep 2, 2012
    Posted by spider73, Jan 28, 2014 #18
    Photogrammetry geotagging dji
    Hello friend,
    reading a lot in the forum shows me that you are the man with the know how for photogrammetric infos on dji WKM.
    So i thought that i contact you and ask you a question.
    I want to make 3d model of a house with photogrammetry and a hexa copter with nex 5n and zenmuse gimbal. IOSD MK2 i also have. Done this 2 years ago with a Mikrocopter UAV and it worked.
    But with my new Copter
    my problöem is that i cant sync the photos taken with gps data log because i think time stamp is not recorder in iosd?? am i right??
    so how do you solve this?? a second external small gps logger unit to put on the copter???
    thanks for any info
    greets from Austria
  19. stasid
    stasid Member
    24
    0
    0
    Oct 25, 2012
    Posted by stasid, Mar 4, 2014 #19
    hi leofuica,
    these info are very useful.
    I have a questions:
    Where can I find the log file with the info of each photo (latitude,longitude,altitude,pitch, roll and yaw)? In my PC or in iOSD?
    thanks
  20. leofuica
    leofuica Member
    83
    0
    0
    Apr 22, 2013
    Posted by leofuica, Mar 4, 2014 #20
    In the log creted in the fly with pics downloaded from your IOSD MK2 to your PC, then export with GPSexporter and you can obtain a log with the gps info
Loading...
Share This Page
Loading...
