http://www.hobbytoys77.com/Discount...e-power---Video-line-FPV-real-time_p2267.html
Functional description
• can transmit gopro3 AV signal to figure (emission) so as to achieve the purpose of real-time video synchronous transmission
, you can directly let the phantom to gopro3 power supply (black gopro3 need to install batteries, silver gopro3 no battery boot)
• has bring hot welding and cold press accessories, whether you have the welding torch can be easy wiring
Packing list
1 x gopro3 av power cord
Common problems
JST phantom a black line to pick up the red line, the red line of the phantom JST gray line, this step must be wrong.
Cold pressing connection method
Will the thrum of the phantom plastic skin to 1 mm or so, the color of the line and then according to the above for good, put JST line along with the phantom power cord into the copper coil, then crushed, and then tighten with heat shrinkable tube insulation.
Hot welding line method
Good will line according to the color of the welding torch welding together, and then tighten with heat shrinkable tube insulation
Packing list
Common problems
