Hi guys...
Selling this hex (well, Y6). Briefly, it's a few-month-old DJI F550 (partial clone), with 3DR APM flight controller, upgraded 3DR uBlox GPS, 915mhz (U.S.) telemetry, carbon fiber props, 3, 5000mah flight batteries (with maybe 8 flights each per battery), extra arms, extra props, and a Turnigy 9X radio.
I have been flying with firmware version 2.9x, as I had some trouble with v3.x...probably has to do with compass interference...but yet to be diagnosed. Anyway, seems to fly fine on v2.9x
Everything is in good/decent shape. As you can see from the pictures I currently have it set up in a Y6 format, but it can be easily converted back to a standard hex...I am including two extra arms, so one more would be needed to go back to full hex (if the deal hinges on that missing arm, I will send another to you
...they are about $4 each.
Everything needed to fly is included, except a charger, and I could include my HiTec multicharger X1 AC plus for an extra $50:
http://www.amazon.com/gp/product/B005LH3392/ref=oh_details_o00_s00_...
I can fly this Y6 in a hover and more (just yesterday I did an auto-trim, and it worked fine...nice and stable), but I have yet to test all the flight modes. Mission Planner works and telemetry works. It has a few bumps and bruises, but I have inspected it carefully and replaced anything that broke, which was typically an arm or a prop (by the way, the carbon fiber props are MUCH tougher than the APC plastic props).
So as far as I know, all is working well...I mean, it can probably use some fine tuning, etc....but it's up to you of course to insure that when you arm the flight controller and push up the throttle, that it'll fly safely, etc. I am selling as-is.
This is what is included...and even if you don't want to fly the Y6 as I have it set up, it can be disassembled in maybe 30 minutes and you can start again from scratch (I could even disassemble it for you if you like).
1) iFlight i550B 550mm hex frame (DJI 550 clone)...$46:
http://www.altitudehobbies.com/multicopter-products/iflight-frame-kits/iflight-i550b-550mm-hexcopter-frame-kit
2) I have replaced all the arms with DJI Arms, so the only iFlight parts left are the center sections...$36:
http://www.uavproducts.com/product.php?id_product=33
3) Props...4, new, 10x4.7 carbon fiber props, 6 used carbon fiber props in various conditions (couple nicks and such, but flyable), 5 APC props...again, with a couple nicks, and 3 unused no-namers...$70:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=380653441192&ssPageName=ADME:L:OC:US:3160
4) 6 Turnigy 750kv motors...$72:
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=12922
5) 6 Hobbyking 30 amp ESC's...$60:
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=15205
6) 3, Turnigy 3S 5000mah batteries, again, only a few flights on each...$108:
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=15021
7) Turnigy 9X radio (firmware from a few months ago...works fine)...the hinge on the antenna broke, so I repaired it (pictured)...$69:
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=19673
7a) Rhino 2620mah 3S lipo battery for the 9X...and I installed an XT-60 for easy charging...$18:
http://www.hobbyking.com/hobbyking/store/__7346__Rhino_2620mAh_3S_11_1v_Low_Discharge_Transmitter_Lipoly_Pack.html
8) 3DR APM 2.5 flight controller in case with side connectors...$160:
https://store.3drobotics.com/products/apm-2-5-kit
9) 3DR power module (included in above):
https://store.3drobotics.com/products/apm-power-module-with-xt60-connectors
9) 3DR upgraded uBlox LEA-6 GPS (bought from 3DR, but I found a listing here)...$75:
http://store.scoutuav.com/product/add-ons/3dr-gps-ublox-lea-6/?gclid=CPOpkeXDi7oCFa1_QgodfFEAuQ
10) 3DR telemetry...bought from here...$30:
http://witespyquad.gostorego.com/3dr-radio-telemetry-kit-915mhz.html
OK...all that adds up to $744...plus quite a bit of shipping ($800 total?).
I will sell for $475 shipped in the continental U.S...or best offer.
Let me know if you want a picture of something that isn't quite visible in the attached.
