JCcreative
This is a DJI F450 Quadcopter. It comes with everything needed to film. Simply take it out of the INCLUDED Pelican Case, put a battery on, and take off. This quadcopter flys great, and has been used to film national television. This quadcopter is ideal for any aerial videography or photography. I have well over 3500 dollars invested with a lot of time building and testing and tweaking to get it to perfection. I am selling it for $2700 or best offer NOW ONLY $2100 FOR EVERYTING
Please email JackCarrollCreative@gmail.com for any questions regarding this quadcopter.
DUAL FPV CAMERAS
This Quadcopter is equipped with a switcher, and dual cameras. One camera is the gopro, for filming, and the other is a small flight cam. You can remotely switch back and fourth between the cameras so you can fly fpv while filming below the quadcopter. It is equipped with an immersionRC 600mw Transmitter, with miles of range. Also included is a iOSD Mini, which gives you live onscreen telemetry such as height, distance, battery, and gps connectivity.
SPEKTRUM DX8 TRANSMITTER
The included spektrum dx8 is the top of its class of transmitters. It is paired with an ar8000 receiver on the quadcopter. I have flown the quadcopter over 2 miles away without connectivity issues, and it should go much much further. The DX8 comes in an atomik case to protect it.
PELICAN CASE
The 1650 pelican case houses everything you need to fly the quadcopter. You can store the quadcopter with blades on for quick deployment. All you have to do to deploy the quad is pull it out of its case, raise the antenna, plug in the battery, and turn on the included spektrum transmitter and FPV monitor.
7 HIGH QUALITY FLIGHT BATTERIES AND 4 MONITOR BATTERIES
Included are 4 ReadyMadeRC 5100mAh 3s Lipo batteries, and 3 Turnigy 5000 mAh 3s Lipo batteries that power the quadcopter. All batteries are very new, and have only flown a few times. Also included are 4 ReadyMadeRC 1100 mAh lipo batteres to power the monitor and the ImmersionRC FPV receiver.
INCLUDED TOOLBOX WITH 3 CHARGERS AND SUPPLIES
The toolbox is a waterproof box that neatly holds 3 chargers, extra props, charging cables, and spare parts. All of this is included, plus a power strip for plugging in chargers.
INCLUDED ITEMS:
Hope that was enough pictures for you Now buy it!
DUAL FPV CAMERAS
PELICAN CASE
INCLUDED ITEMS:
- Pelican 1650 Case with custom foam insert.
- Waterproof Toolbox for chargers and spare parts
- DJI F450 Quadcopter
- Zenmuse h3-2d Gimbal
- Gopro Hero 3+
- Onboard Flight Cam
- Naza m V2 flight controller with GPS
- ImmersionRC FPV 600mw Transmitter with spironet antenna
- iOSD mini Onscreen telemetry display
- Onboard FPV Camera Switcher
- Spektrum ar8000 Receiver
- 6 Spare sets of props
- DuBro Prop Balancer
- 7 flight batteries
- 4 monitor batteries
- Spektrum DX8 with Atomik RC Case
- 2 Battery monitors
- 5" FPV Monitor with custom mounting bracket
- ImmersionRC FPV receiver with spironet antenna
- Vista battery charger with builtin power supply
- turnigy battery charger with power supply
- imax battery charger with power supply
- 5 Charging harnesses.
- Gaff tape for balancing props
- Spare parts and cables
- Power strip
- Spektrum remote control charger
- Extra Velcro
- Small toolbox with prop tools and battery adapters
