Olemil
Well I have to break down and get some advice from the pros. I am new to the MR world for sure, been flying helis for a few years now but this is a little different. I have a stock F450 with Naza controller including the GPS unit. I am also running the DJI 10" (1038) props with a 2200mah 3s pack mounted on the top frame plated. I'm using a Futaba 8FG tx with a S-Bus rx. Trying to get this dialed in but not sure what I should be expecting. Every time I've been out with this, there's been some sort of a breeze anywhere from 3-10+mph. I guess my biggest question is how are these supposed to react in wind? Mine the way it is set seems to rock side to side (bobble?) with a gust of wind while in GPS mode. It isn't anything violent but it does rock side to side. I have everything set up and programmed as per instructions including calibrating compass (outside away from any obstacles). My current settings are as follows: I have the Basic Gain pitch and roll set up with a knob on my 8FG (running at 150%), yaw set at 110%, vertical 110%, Attitude gain 140% on both pitch and roll. Now if there is a way to tame the wind effects, which one would I adjust to take some of the bobble out? This is a new game to me like I said, seems simple on a heli, adjust the gyro until tail wags then back it off. Thanks for any help you may have and sorry for the newbie question that I'm sure has been asked 1000 times. P.S. I have a set of Graupner 10x5 props on the way if you think that will help.
