Differance between prop types
How does the prop type affect the flight of the multi-copter? I'm flying an octocopter and right now it has CF 12x3.8 props. If I were to switch to wood or APC (are those plastic?) but with the same specs, how would that change the response of the copter?
How about if I changed the size of the props and went with a Graupner 14x8 prop or a 13x6.5 prop - how would those things affect the flight generally speaking?
Am I correct in saying the less pitch a prop has, the smoother the flight and better it is at having less vibrations. The down side is less maneuverability but more efficient?
So ideally I might be looking for the flattest largest props for the least vibration on the octocopter for shooting film?
yes... I am a noob.
