As most of you know I recently had the compass board go bad on one of my Hexa, dead, no lights, no power. OK, order a new board and see if the old one can be fixed when I have nothing better to do. New board arrives, I solder the header to the board, install, and go through the calibration routine, nothing, still red light on Navi and Mktool says bad compass error, hmmm...
Tried it a couple times to make sure I wasn't doing something wrong, same result. Went so far as to remove the compass board and install it in the stack of the other Hexa to see if maybe it was something wrong with another board in the first stack, same result, could not get it to calibrate. Great, a DOA board from vendor stock, now I have to RMA the thing and who knows how long this is going to take to get sorted, meanwhile I have no GPS nav on my backup AP craft.
Back when I first built my original Hexa I had the exact same problem and it turned out to be a simple fix once I really dug into it and found the root of the problem so I figured I had nothing to lose trying it again, see if you can spot what's wrong in the picture and remember this is a brand new board from MK...
As it turns out this is EXACTLY the same thing that was wrong with the original board I had over a year ago! What are the odds of that happening? Pretty good apparently and now if I run into this again I'll know right where to start troubleshooting. But Mk never sends out defective boards don't you know, it's always the end user that damages them after receipt, or so they say. Ok, then explain this, not once, but twice and I've got the photographic evidence to prove it...
Here's the first one though the picture isn't nearly as clear as this time around unfortunately...
P.S. once I fixed the problem it calibrated on the first try...
