Nick Wolcott
It's got plenty of power, I did 25 pound test payloads at 5000 feet, and it handled nicely, motors and ESCs stay cool. It's efficient - 10 minute flight times at sea level carrying a Red, Movi, and 2 pound lens. I stopped using it when the Alta8 came out because the Alta is so easy to travel with. But this X8 will lift just as much as the Alta8, and I'm selling it for less than a third of the cost of the Alta. The build and break down really isn't too bad, The oblong shape of the booms ensures the motor angles are the same for every build, so you just have to plug in the motor wires and LED power wires and tighten the metal boom clamps, then attach the props and you are good to go.
I am selling two of these, so if you would like backup redundant system buy them both.
One I built as a backup to the original, it has ESCs located on the booms so the props will cool the ESCs. It is new, it has never been used on a job, just test flown to make sure everything was working well. I've priced them both the same because the new one only has LED lights on one boom as opposed to all 4 on the other one, it also does not have an FPV camera. It does have IOSD, so you just need to add the FPV camera.
Included with purchase:
Mid-Atlantic x8 frame kit made with nice thick strong carbon fiber
DJI A2 flight controller with IOSD for FPV overlay and the upgraded pro plus gps puck
4 pairs of T-motor carbon fiber props 18x6.1
8 Tiger Motors MN4012-9 480 KV
8 HobbyWing Platinum 50A ESCs
Power Hungry distribution board
Movi mounting plate with Toad in the Hole and Freefly vibration isolators
Pelican 1620 case
Not included:
Futaba controller
batteries
Movi or gimbal
landing gear
Pelican 1620 case
Not included:
Futaba controller
batteries
Movi or gimbal
landing gear
