ok it is the time to show what i have done during the last week...
as announced into another tread i have made a quadcopter but as i need more lift i have done a conversion to X8 coaxial and as FC i only can use my naza Mv1 with firmware update.
all start some month ago with hours spent to drowing my oun chassis plate, after have cnc machined with my little home made cnc mill and this is the result
here the two plate assembled with self made boom block
for thi built i have this items
8 mt 2814-10 770kw tiger motors
8 dji 30A opto , the upper esc was hacked and i have pull away the connector and soldered some wire, also add heat sink as the must work into the dome.
naza mV1 with latest fw upgrade
after a lots of hour of screw-unscrew , try, try again , solder, solder again here there are the final result.
down side esc
with custom made power board
upper esc
and naza in place
motors with custom made 3w led light
all completed and need only to buy the propeller
the setup
AwU 4.200kg
complete of:
gimbal, camera, fpv, video tx, mini 3s batterie for gimbal, led, fpv gear.
2 lipo 4s 4000mha
landing gear
dome
so at this step i need help from you friend who have just used my same motors... wich is the best prop i can buy?
for the test i will try 12x3.8 APC SF as e-calc say they must be nice and give me the right amount of thrust and hover time.
what do you think?
hope my little hand craft work is appreciated as i put on it a lots of time and heart.
hope to can have any kind of help and comments
ceers
peppe
down side esc
upper esc
and naza in place
the setup
AwU 4.200kg
complete of:
2 lipo 4s 4000mha
landing gear
dome
what do you think?
ceers
peppe
