Can't get into GPS mode
Flydigital
When I power up my Telemetry indicates I'm in GPS, just for a second and then it jumps to ATTI and stays there. The GPS switch won't make it go back.
This is a new, non-DJI (but advertised as compatible) GPS unit. Do I have a faulty component or is there something I can try to get it working?
DJI F550 Naza v2
Flydigital
Thanks. Yes it seemed to show up as I was setting up then dropped off once I had it all set in place. Clearly a mistake going for the cheap option!
I've got a Naza controller and a "compatible" non-DJI GPS with *no* problems (works great, actually). Have you tested the switch you are using for GPS/Atti mode while connected to the DJI configuration software? I had a heck of a time setting the curves/functions on the switch input to hit the modes I wanted in the DJI configuration. Make sure that the switch is functioning correctly there, and you'll probably be able to see in the configuration tool if the GPS is somehow coming disconnected.
