Can't enable Voltage Monitor protection
aWanderer
Hi,
Anyone have any idea's as to why I cannot access anything on the Voltage tab in the Naza Assistant software?
Everything is disabled, cannot enable it.
RTRyder
Merlin of Multirotors
Hi,
Is the VU plugged into X3 and LED port and everything powered up? If the Naza is seeing the VU on both the canbus connection (LED) and port X3 you should be able to turn on voltage monitoring with a fully charged battery connected. If not you may want to bring it to the attention of the dealer you bought from, they can work with you and DJI if necessary to fix the problem.
aWanderer
I'll double check, but I soldered the wires to the contacts on the board and plugged it into the FC. When I first hooked it up to the computer, the Voltage monitor was ON, but VOL-LOW[4] was flashing at the bottom of the window, so I turned Voltage monitoring off. Rebooted everything and now I can't turn it back on at all.
On a positive note, it fly's awesome! I've only had one flight with it. Just finished building it last night. Anyway, thanks for the response. I will double-check everything when I get home.
aWanderer
This was an ID10T error. I had the cable plugged in to X2, not X3. So... for the record, if you see an error in the assistant flashing VOL-LOW[4] then check the plugs :)
