Greetings all...
Just got a Dromida Ominus FPV. Aside from the transmitter being broken right out of the box (bad on off switch...just touching it after you turn it on is enough to disconnect it...hence I have tested the resilience of this quad falling out of the sky quite a few times). Anyway, I digress......When I charge the batter it indicates it's charged in about 20 minutes, but I can only get about 4 minutes flight time...even without using the FPV function. Dromida "claims" 12 - 15 minutes, so realistically I figure I should get ab0ut 8 - 10.
Anyone got any thoughts as to weather the charger or the battery (or both) are bad and an easy way to test them to figure out what the problem is?? Thanks in advance for any help. : )
