Building up heavy lift Quadcopter.....I have some Axi 2814/22 motors, running on 4 cell 5000mAH Lipoly with Hobbywing 40Amp speed controllers directly wired (no connectors).
Just running one motor direct to the receiver for rotation direction and ESC tests......I have selected Medium timing on the ESC....The motor runs OK up to about 1/2 throttle , but then ‘pulses’ violently above 1/2 throttle (using a 13 x 6.5” APC electric propellor). , I have tried Low timing with similar results and High timing is much worse....it's OK on 3 cells........... HELP please!
