I just hooked up my brand spanking new AV130 to my new (used) AD6 HLE and the servos are making an awful buzzing sound. They are hooked directly into the correct ports. What's going on?
ken
i've got two servos with external pots and gear drive that are pretty quiet. usually the buzzing is worst when the belts are too tight. tight airplane pull/pull cables will make 'em buzz like that also. it's not the end of the world when they're buzzing but if you can loosen the belts a tiny bit the servo will appreciate it.
are they Hitec servos? what voltage are you operating the servos at?
I use the CC 10A bec, small and adjustable to 9V max, works flawlessly.
