AV130 Gimbal installation problem
Topflight
Purchased an AV130 gimbal and a landing gear that was supposed to work with that gimbal. After receiving it and putting it together, I find out that there is not enough clearance for the gimbal using that landing gear. So then I order an AV130 landing gear specifically made for the AV130 gimbal. I received it today and after putting it together, I find out that there is not enough clearance to mount the strut to the gimbal because of the motor on the top right of the gimbal as you look at it from the rear. I can file it down to make it work, but I would think it would be better engineered. Also, on the left side (looking from the rear) the servo motor hits the aluminum cross member. Anyone else run into this?
