Any missing or incompatible parts in first build list?
skatastic
I've never built or even flown a tricopter but I'd like to build one. I don't think I'd be too interested in putting a camera on the rig but, at least eventually, would like to be able to do flips and what not.
Here's what I'm thinking about buying...
3x Turnigy Plush 30amp speed controller $12.19
http://www.hobbyking.com/hobbyking/store/__2164__turnigy_plush_30amp_speed_controller.html
Gold Connectors $2.06
http://hobbyking.com/hobbycity/store/uh_viewItem.asp?idProduct=36239
3x D2826-10 1400kv Brushless Motor $9.48
http://www.hobbyking.com/hobbyking/store/__12920__d2826_10_1400kv_brushless_motor.html
Mounting pads $1.99
http://www.hobbyking.com/hobbyking/...light_controller_mounting_pad_10pcs_bag_.html
HobbyKing KK2.0 control board $29.99
http://www.hobbyking.com/hobbyking/...2_0_multi_rotor_lcd_flight_control_board.html
4 10inch props (2 counterclockwise, 2 clockwise) $3.14
http://www.hobbyking.com/hobbyking/...tandard_rotation_2_pc_rh_rotation_black_.html
10pc set10cm male to male servo lead 26awg $4.75
http://hobbyking.com/hobbyking/store/__21758__10cm_male_to_male_servo_lead_jr_26awg_10pcs_set_.html
BMS-385DMax Digital Servo $20.48
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=8761
3000mah turnigy lipo pack $20.66
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=15010
lipoly lock strap $4.90
https://www.hobbyking.com/hobbycity/store/uh_viewitem.asp?idproduct=17410
hobby king 2.4ghz 6ch tx & rx (mode 2) $25.07
http://www.hobbyking.com/hobbyking/store/__9042__hobby_king_2_4ghz_6ch_tx_rx_v2_mode_2_.html
hobbyking 105w 15v/7a switching dc power supply $13.99
http://www.hobbyking.com/mobile/viewproduct.asp?idproduct=20971&type=&idparentcat=467
hobbyking dc-4s balance charger & cell checker 30w 2~4s $8.99
http://www.hobbyking.com/hobbyking/...69A02C-22BB-4712-80FA-8B47368F400E&aff=116537
simple tricopter frame $29.99
http://www.simplecopter.com/new-simple-tricopter-aka-cheap-easy-tricopter/
Is there anything that I will need that isn't on the list? Are any of the things on the list incompatible with one another? ie. charger doesn't go w/power supply? Receiver/transmitter sufficient for capabilities of board/rig?
I thank you for any advice you can give me.
skatastic
Can I make that by splicing wire together or do I actually need a board?
That being said I guess I should have asked what am I missing that I can't get from home depot. Obviously I'll need some wire, solder, heat shrink.
bradh79
Yes you can make them I got my quad one from 3dr that had Speed Controllers inputs attached to it all
Sent from my GT-I9100 using Tapatalk 2
PeteDee
Mr take no prisoners!
2-3S rated motor and 4S battery pack will most likely cause tears, not a fan of collet style prop adapters either.
Get a better power supply and better charger, spend it now and you will only spend once.
I might be happy to pay $5 for that frame, build one yourself for $4.
Pete
