Welcome To DroneVibes
an unusual configuration for an X8
Discussion in 'Beginners Drone Forum' started by Kevinbx, Mar 5, 2014.
  1. Kevinbx
    Kevinbx New Member
    4
    0
    0
    Mar 5, 2014
    Posted by Kevinbx, Mar 5, 2014 #1
    Dear all. im a bit new in this business but i managed to build some experience in the past 2 years. right now i am truing to build a new X8 with the following configuration CWS frame with 900MM motor to motor DJI flight controller 8x 40amp Turnigy Plush ESC 8x T-motor 3508-16 kv700 untill here everything is pretty ok and regular, this configuration always ran on 4s batteries with 12x5.5 CF propellers. the trick i want to apply and im not sure if it will work i want to reduce the battery power to 3s packs and step up the propellers to 15x5.5 or even 16x5.5 the Ecalc website shows a stable result when i ran the numbers. but i thought before i embark on such an adventure i must ask for advice. now comes the second question is about T-motor 4014 400kv, the same site Ecalc.ch shows that this motor cant handle a combination of 6S and 17x5.5 without getting too hot. the T-motor website says it can handle it http://www.rctigermotor.com/html/2013/Navigator_0910/40.html hopefully someone have some idea and can shed some light on that issue. Thanks alot in advance for this help.
    Tags:
  2. stevemaller
    stevemaller Heavy Lifter
    311
    68
    0
    Oct 19, 2012
    Half Moon Bay, CA
    Posted by stevemaller, Mar 5, 2014 #2
    The motor table is based on 6S batteries. So unless you’re planning to run two 3S batteries in series, there’s no way a 3S LiPo will spin a 16” prop. At least not in any of the physics models I understand.
  3. Kevinbx
    Kevinbx New Member
    4
    0
    0
    Mar 5, 2014
    Posted by Kevinbx, Mar 5, 2014 #3
  4. Kevinbx
    Kevinbx New Member
    4
    0
    0
    Mar 5, 2014
    Posted by Kevinbx, Mar 5, 2014 #4
    As you can see the in the 700 kv version the table show it can handle a 13 inch on 3s my question is would it be possible to put bigger props
  5. Kevinbx
    Kevinbx New Member
    4
    0
    0
    Mar 5, 2014
    Posted by Kevinbx, Mar 6, 2014 #5
    some answers.
    common people,i really do need some advice about these two issues.
Loading...
Share This Page
Loading...
