The AKASOX8C quadcopter is a large and stable drone that is capable providing high-flying aerial shots. If you're looking for a quadcopter with protectors and improved durability, then AKASO X8C drone is the one to go for. It has been designed with protectors to guard it from bumps and bruises during the flight. One of the main benefits of this drone is it's 100-meter range. This capability allows you to capture amazing aerial footage. Also, due to its large size, the RC drone can hold itself when flown in the wind. Even though it is bigger in size, this quad is lightweight and can fly fairly well. It also has an LCD that provides the user with more information concerning various functions. When it comes to signal, this drone has strong signal which you can pick easily when it's far away. However, it has a height limiter that prevents it from going too far up where it can loose connection with the controller.
Features and Specifications
. AKASO X8C drone is designed for all users and its also easy to operate for beginners. It's 6-axis design gyroscope makes it adjustable and stable. The controller uses a 2.4GHz frequency for a faster and improved control while consuming less battery power.
. Has Built-in HD Camera - The HD camera allows the users to take shots and videos while flying. That means you can easily capture your family and friends from aerial view shots. The drone is controlled by a powerful 2.4GHz transmitter that is interference-free. This eliminates interference by other quadcopters. Another impressive feature about this transmitter is its range, which is 100+ meters.
. 360-Degree Flip - With this drone, you can do incredible 3D flips and roll it by a push of a button. The flashing LED lights provides an excellent flight experience at night. You will get some great view anytime you play stunt at night.
. More solider protection - The X8C quadcopter has propeller blades that are protected using high quality frames that help to reduce impacts from collision effectively.
. 4.5CH - comes with a 6 Axis Gyro - It's channel provides strong stability, strong wind resistance, easier to implement different flights and easier to control.
High Flight Performance
With it's propellers safely guarded by plastic frame, this drone is suitable for flying either indoors and outdoors. Propellers are about 9 inches long and they're made of very high quality material. It's flight time is between 5 and 7 minutes with flight distance ranging between 50 and 150 meters.
Colorful Lights
The X8C drone has lights on the underside that allows you to know the front and rear at night or in a dark place. The controller pairs quite easily and has controls for the HD camera for taking videos or photos. The battery compartment for AKASO X8C is very clean, and can fit a 2,000mAh battery perfectly without having to jostle around in the mid-flight. Additionally, X8C also comes with the red/green LED lights which help you to easily track your drone during the night flight.
Flight Mode
AKASO X8C has various flight modes that makes it easier to maneuver it. By pushing the speed button, the quadcopter goes to high performance mode. When stable, you can get the drone to do more tricks. Some of the maneuvers include upward and downward, rightward and leftwards and the 360 degrees roll, among others.
Headless Mode
The AKASO X8C offers a unique feature commonly known as Headless Mode. This is basically a feature that takes away the worries of orientation of the drone, which actually makes it easier to control your drone. In addition, the control is pretty straightforward, just configure the quad so that its front is definitely your front before the takeoff. When it comes to direction, you can either press right or left to move your drone to the direction you want.
Pros
. Propeller protectors - AKASO X8C propeller blades are well protected by high quality frames that minimize any possible of damage from the collision. The frames are placed slightly below the propeller.
. Controls - The controller can be operated easily by all users and even the beginners. By a push of a button, you can flip or roll the drone in whichever way you want. It's also possible to turn the quad to any direction either left or right.
. 6-Axis Gyroscope - This feature adds to the benefits of this drone. It provides better stability, resistance to wind and easier to control. In addition, it consumes less battery power.
. Applicable in both indoor and outdoor areas - With this drone, you don't have to worry about taking photos or video at the indoor place. It performs well for any indoor function.
. HD Camera - It has in-built camera that helps the users to amazing aerial shots and videos. Its a neat looking camera which is almost the size of a GoPro.
. Lightweight - The AKASO X8C quad is a lightweight drone, which means you easily move it around on the ground and can gain height quickly within a few minutes.
. The drone provides tons of power, great stabilization and descent flight time. It's transmitter range is also great which is way above the average for any drone that is priced under $100.
. AKASO X8C is also affordable.
Cons
. Camera quality is average for this drone
. It's also a little bit tricky to maneuver X8C especially the beginners.
. Due to its large size, it can be very unforgiving during a crash.
. It takes a little longer to charge an X8C battery - can take up to 180 minutes.
Conclusion
AKASO X8C is a revolutionary quadcopter compared to many other similar drones. It comes with many benefits that you will enjoy as a first time user or experienced user. You will definitely love to take great pictures from different angles and also enjoy to see the world from different positions. It's also durable meaning that you're looking forward to get a long service from this equipment. The drone is also cheap, so you have to break the bank to get one. Compared to many other drones, this is the best bet to go for if you are planning to buy affordable quadcopter. It's definitely a value for your money.
