700 CCD FPV camera & 7''FPV 5.8G LCD MONITOR(5.8G receiver) & 5.8G 500mw Tx
Fred ou
hobbytoys77.com
Only need buy this set,you can realize your FPV dream.
http://www.hobbytoys77.com/700-ccd-...d-monitor58g-receiver-58g-500mw-tx_p2173.html
1,built-in 5.8G receiver, 8 bands
2,800*600 HD display resolution
3, with built-in 2500mah lithium ion battery, the 2S series power supply,battery through capacity, packet detection and matching, and has a built-in charge discharge protection board, display positive voltagedisplay light, green light that is working, a long red light indicates that the power shortage, need to charge, when the light turned red, the display can also for another 20 minutes.
5.8G 500mw 8CH Tx
New 5.8G 500mw 8CH TX could offer you extremely long range with just its stock 2dbi antenna, tested 2-3 km in the air and over 5km with a 12dbi patch,
the dual av output on the unique receiver allows you to connect your goggle and possible recorder to the receiver at the same time.
700 CCD FPV camera
Features: 1/3 Sony Effio-E 700TVL single board, 0.01LUX size: 38X38mm, color to black (D/N), infrared, OSD menu function, 2D, DC12V, 70mA.
Model: SONY Effio-E 700 line 32 board (673/672+4140)
CCD type: 1/3 Sony 960H CCD Sensor
Size: 30mm*30mm, plastic PTZ camera match, most of 700 lines are larger than the size of the camera, PTZ camera plastic is not.
The total pixel: PAL: 1020H × 596V (610000 × 508V (like) NTSC: 1020H 520000)
Effective pixels: PAL: 976H × 582V (570000 × 494V (like) NTSC: 976H 480000)
Signal format: PAL/NTSC
Resolution (horizontal center): 700TVL
Digital noise reduction: 2D digital noise reduction (2DNR) support 0~15 16 level can be adjusted
Wide dynamic: digital wide dynamic (adaptive color reproduction)
OSD menu: support (buyers need to purchase another OSD menu line)
Minimum illumination: 0.01LUX/F1.2
SNR: ≥ 48dB
Video output range: 1.0Vp-p/75.
Automatic gain control: 0.25/0.50/0.75/1.00 four level can be adjusted, can be up to 55dB
White balance: open / close options
Backlight compensation mode: high brightness backlight compensation (HLC) / backlight compensation
Exposure mode: EE
Electronic shutter: 1/50 (1/60) - 1/100000 seconds
Gamma correction: 0.45/1.0
Synchronous mode: internal synchronization
Audio: optional
Working voltage: DC12V ± 5%
Working temperature: -20 ? --60 ?
Humidity: 0% ~ 96%
In order to terminal user, we're asking manufacturers in the product with the transmission connecting terminal, practical ability of users can change their head, lighter weight, connecting more quickly.
