580 size Foldable Quadcopter MQ600 with camera amount Super Stable from Soodohobby
  • Super Stable
    Votes: 1 100.0%
  • Super Fun
    Votes: 0 0.0%
  • Good for aerial photography
    Votes: 0 0.0%
  • 580 Size
    Votes: 0 0.0%
  • Total voters
    1
Freeshipping from [url]http://www.soodohobby.com[/URL]
Quadcopter MQ600 flying in the woods, pls see the video on the youtube: http://www.youtube.com/watch?v=xPK9Y6vXB3Y&feature=plcp
Overview
The 1147 carbon reionforced Propellers fitted super efficient 750kv brushless motors,brushless controllers and MMC10 quadcopter autocontrolller give an extended flight time of around 12 minutes with a standard 2200mAh Li-Po battery. The low rotor speed makes it a very stable platform capable of carrying a payload of around 2kg - almost double that of many other quads.
Technical
The Soodo quadcotper MQ600 flight controller has the nine axis sensor with high sensitivity including three axis Gyros, three axis Accelerometer and three axis compass which makes it easily to be flyed; Very suitable for the beginners.
-MQ600 is our latest mid-level aircraft model designed . It’s for flight photography players.
-High efficiency: with 1147 carbon reinforced propellers and brushless motors. The optimal working efficiency can reach 11.5g/W.
-Stability: take high-performance MEMS sensor for 6DOF stabilization with low drift, shock resistance ability.
-Simple: only require 4channel to fly. Property core system, it is compatible to all RC equipments
-Easy to use: can be installed quickly, easy to operate, and support planar self-stabilizing PTZ function.
-MQ600 can take off and land vertically, spot hover, altitude hold, fly left, right, etc.
-Install a camera mount at the bottom of the aircraft. You can adjust pitching angle of PTZ through RC. Suspension system with high-efficient filter function and low frequency vibration is used to connect camera mount and aircraft. Camera mount swings on the cross beam of LG, can be installed and dismantled quickly
Specification
Weight :1060g
MAX payload:2kg
MAX carry payload:500g
Motor:MOTOR4008 KV750
Propeller: 1147 Carbon Reiforced Propellers
Frame:Glass Fibre and Aluminum CNC
Landing gear:plastic
Battery:2200mah 3s /4S
Flying time:12min
Controller:MMC10 quadcopter autocontrolller
MAX current:15A <!-- start: postbit_attachments -->
View attachment 5643View attachment 5645View attachment 5646View attachment 5647View attachment 5648View attachment 5649View attachment 5650
Orracle
Wow, can't you even take your own pictures? There is clearly another companies water mark on the picture (motionpixel). They sell an improved version of this quadcopter, the one shown in the picture, with tiger motors and their own custom made motor mounts. Your description does not match the picture, just because your water mark is bigger it doesn't make it yours.
Thats Sad, using someone elses work, Shame on you soodohobby, I dont deal with people wanting to make a quickbuck off others hard work
