4.22 question
jhardway
I know in the past I have read some issue with Attitude warning with the 4.22 release. I am wondering if people are still seeing some of those issues. I believe it may be something happening here on my craft. Until I downloaded the newest the release the other day everything has seemed to be OK. Now I am seeing a lot more white flashes with my copter a long with a little more wobble like the IMU and the GPS are not getting along.
Any ideas.
RTRyder
Merlin of Multirotors
Any ideas.
I have the re-release of 4.22 on both of my WKM, the CineStar I haven't noticed the white flashes but on the quad it seems to be happening everytime I do anything other than slow steady flight, was fine on previous versions where I'd have to slam the sticks around before the LED would flash white. I'd say it has to be something they did in the code and it doesn't seem to affect the way the quad flys so I'm not going to worry about it. I think I'm not seeing them on the CineStar mainly because I fly it steady and level 99% of the time, If I did a couple piroettes with it I'd probably see the white flashes appear.
I did notice I had to do some gain adjustments after the upgrade to get things back to where they were before so you probably need to do the same to get it flying smooth again. The alternative is to just revert back to 4.2 and wait for the next release.
Any ideas.
i had to increase att gain back to nice and smooth!
jhardway
So I took a step back in software and my ATT light issue are now gone, Exopackshiu when you have time would you be willing to pass along your gain settings. It is just to see where I am in my relm, to compare and check base.
thanks guys.
Jack
thanks guys.
Jack
basic gain - pitch and roll 140 % yaw 130 % vertical 110 % att both are 100% motors are avroto Esc 30 amps x650v frame 4s 4000 mah- Grand total weight is 2.1 kg
shiu
