2G4 Patch Antenna
OneStopRC
Dirty Little Hucker
2.4 Ghz Patch antennas for your VRX Groundstation system..
The 14dBi Patch antenna from Team BlackSheep is made for the travelling enthusiast. It is a compact, square antenna with a hard plastic shell for ultimate protection. It works well across the whole 2.4GHz frequency band and gives between 7 and 12km range with a 45 degree beamwidth.
A supplied M5 screw receptacle allows quick mounting to almost any camera tripod. The hard back is perfect for taping battery and video receivers. This gives you the ability to quickly snap-in and remove the antenna along with the whole ground station from a camera tripod. Perfect for a durable travel-groundstation.
[h=2]Technical Specifications:[/h]Gain: 14dBi
Polarization: Linear (Horizontal or Vertical)
Horizontal / Vertical Beamwidth: 45 degrees
Working Frequency: 2370MHz - 2510MHz
Antenna Dimensions: 21cm
Cable length: 30cm
Connector: SMA
$69.90 + Priority Shipping... USA only.
https://onestoprc.com/home/37-4-ghz-patch-antenna-14dbi.html
