Jim in Massachusetts
My DJI worked fine when I first set it up.
1.) Now however, with no stick input, in GPS mode, it revolves around a 12-15' circle when it should be relatively stationary.
What do I need to tweak to minimize this? Could it be a center of gravity problem?
2.) When I switch my DX8 radio to fail-safe, the craft returns to home OK.
I want to know, is there a way to turn off "fail-safe" "Return to home" so that the craft can be manually landed or returned to GPS mode without landing first?
When I flipped the switch back to GPS, the craft continues to RTH.
3.) I currently do not have Intelligent Orientation Control turned on in my Naza set up.
It seems I should, in case I loose orientation when the craft is in the distance. Any tips for setting up this feature?
Thank you in advance for any help and tips.
