OneStopRC
Dirty Little Hucker
Well after reading the horror stories with the DJI Standard props, I went off to order some replacement GemFan Black Carbon Mix 10x4.5 (DJI Motor), of which are a direct replacement for the DJI props. Can't beat them for $2.00 a prop!, anyway, while I was looking at my motors, I span the props and found a noisy one, turns out I have a bad bearing on one of them.
Same place has replacement bearings for the DJI 2212 Motors, shaft seems ok as there is no movement of the blade, but I can feel it loose within the bearing. Just think, the next flight could have cost me a lot more than $20 and some change.
My point is, make sure you check your blades, motors and bearing before each flight. It might save you a couple of hundred $$ if you do.
If your wondering where I got these blades and bearings.... go here. https://www.gothelirc.com/shopdisplayproducts.asp?id=178&cat=GemFan+Carbon/ABS+Mix+Prop
