Highalander
Hi All, can anyone advise on which gains to adjust to stop the s800 drifting to the left. I've tried several different amounts of gain but still get the same result, release the sticks and it starts to drift left!
There is a magnetic declination everywhere in the world, and this will sometimes effect the wookoog drifting. Here in California, the Declination was approx 12 deg.
See Here for your Declination http://magnetic-declination.com/
For my copters, I usually rotate the GPS disc approx 10-12 Deg, and this cures toilet Bowling and drifting. Sometimes, it works perfect without having to adjust the GPS Disc. If I were in your shoes, I would simply turn the GPS Disc in one direction a few degrees, and see if the drifting gets better or worse. If it gets worse, then go the opposite direction until you get a good setting.
Hope this helps.
Patrick
