TooManyHobbies
Hi guys, I was finalizing some wishlist equipment for a bunch of stuff going on a FPV DJI F550 build.
An additional Wookong Data link with a single waypoint upgrade may be "tossed in".
What do you guys think of a basic Acer One Notebook Computer or other?
I'm a bit nervous as to what works well for our FPV idea.
We grew up with dirtbikes and ATVs, and will be toying with some FPV cruising of the open and tight areas.
- Last, but not least, some typical FPV hill climbs and decent.
http://www.youtube.com/watch?v=fblsmx5S3CU&feature=player_embedded#!
Cruising with the ATVs would be a dream.
I believe an EZ OSD can help inform me of some telemetry info, but the data link on a notebook can too correct?
Which do I choose as lines of defense for keeping track of the copter when things are not working correct (Murphy's law)?
I hope to get some great ATV (4-wheeler) scenes.
We will be seated (ground station) near a lush wooded area with some barns scattered in the area.
-Not sure if the woods are even going to work terribly against us.
We'll test for weak transmission, but would like some advise for skimming tree-tops and open straight-a-ways.
Here is some of the equipment.
On the Ground
Eagletree Eagle Eyes Diversity controller
Dual Receivers for ground station. Both Optimized with better RF filters
1 patch antenna
1 Dipole antenna
3S lipo to power entire ground units.
Custom Wiring Built to power Receivers, Eagleeyes and spare plug for LCD monitor
All video cables needed.
What's included on copter.
Video TX
V antenna or Cloverleaf on TX
12 Volt converter installed onto F550 Power Dist Board to power cam and TX
Cables optimized for running video and power, to a FPV Cam (Purchased Seperately) and to Video TX from voltage converter.
Second cable to go from GOPro into TX
This is set up to use go pro as the FPV cam.
I need a universal plug for a separate FPV Cam that we'll switch out with the GoPro to see what we like better.
This is our 1st FPV attempt, so we may be missing a bit!
When I first started reading up on things, I thought that the Dragonlink was the "cure-all" for the project.
- I was under the impression that if things got bad, I could slowly pull up, use telemetry and try to squeeze back into the range of video transmission.
I'd love to use the Wookong "return to home" aid, but fear that it may drive me into a unwanted area or something.
Lastly, I may have to just settle for more open areas, but this is our private property and it's all we have!
Thanks for any tips.
On the Ground
1 patch antenna
1 Dipole antenna
Video TX
Notes:
ezUHF is still an option (DL "dragonlink" is no where to be found).
I use a JR 9503 Tx. ezUHF is still an option (DL "dragonlink" is no where to be found).
