homer911
Very sad day........My very first multirotor crash. But it was mainly my fault. The battery voltage dropped to 3.4 per cell and I lost orientation so I hit failsafe. It started to return SLOWLY!! I seen that the voltage was dropping rapidly so I tried to switch it back to ATT mode but it wouldn't switch over!! I'n not sure I have even tried the failsafe switch in flight before this event. BIG MISTAKE!! It worked fine in the assistant software and I have tested switching off the tx in flight and that worked fine. I should land a lot earlier to give buffer.
I quickly looked down at my telemetry before It dropped like a stone and I think it said 1V !!!!! Bummer. Dropped from about 15ft. It was painful to watch. I checked the battery voltage after and all cells read 3V or 3.1V. It puffed out as well. I take it I shouldn't use it again??
Mechanical damage - all gear rails of the landing gear need to be replaced. I was lucky!! It could have been a lot worse.
I had a look for some Droidworx spares on the Droidworx site, AU$ 12.50 each. €19.99 from an Irish website. Big difference. Is it possible to order direct from Droidworx?
