What kind of UBEC?
Zzr
Many Thank Tomstoy2,
I have one question. removed the signal wire from the servo's connector and put it into empty servo connector. Y from black ground put it into servo connector then plugs into controller. Two powers wires to Ubec. Where do I find wiring diagrams picture.
Oh yeah, I have one, works very well! Never regretted buying it.
CC 10a bec is a good one, too.
Im using the CC 10amp that everyone else uses. Its great other than it is a PITA to change output voltage! I still havent purchased the usb link to do so and am confined to the default 5 volts. I think it would be best to jack up the voltage to 6 volts for a gimbal to respond quickly.
Zzr
Thanks IrisAerial,
If wiring two servos to Y-harness plugs UBEc? How many amps output?
I cut my power wires coming from the flight controller to the gimbal servos. Then just solder the bec output to the power wires of the servos. It's pretty easy really. I also added the negative from the bec to the ground of the servos as well.
Zzr
Both cut + and - wires from the flight controller to the gimbal servos?
Zzr
F1 and F2 black wires to servos?
Zzr
I just got UBEC and Y-harness. I removed Power wire from Y-harness. Is okay this picture?
Zzr
Should I cut orange wire (signal) from UBEC? I leave for + red and - black wires.
