iceman
Pan system: I zeroed all gains and did the pan center tune without the gimbal attached to the copter and found the center tune i.e. the servo stopped rotating. Saved it. After that I adjusted pan position gain to 100 and pan velocity gain to 60. Attached pan input and pan servo cables to reveiver and servo.
After connecting power, the pan servo started rotating quite fast. (gimbal was still not attached to copter) Once I tipped my aileron stick to the other direction - pan input was connected to aileron channel - the direction of rotation changed but the speed remained the same.
After this I connected the pan servo directly to aileron channel on the receiver. Once again the pan servo started to rotate but I managed to stop rotating with subtrim. Pretty much was needed. -51 on Futaba T8FG. Pan was really sensitive so I used minus expo as much as possible (-100 both ways) to smoothen the start of the pan movement out.
Is the pan even planned to be plugged into Skyline with the present 1.2.2 firmware or should it be plugged into the receiver like I did? Have I done everything correct with the pan setup or is there something to improve?
I had this problem even when suspending the frame from the ground, it doesn’t help that Photohigher don’t say if you need the resistors plugged in like you do with tilt and roll so I added the variable pot that came with the original servo and re-connected that. After a small adjustment it stopped the rotation of the pan servo however for me it was still not a workable solution as there was terrible jitter in the pan axis with small left/right yaw. I have been told this is due to the dead band of the original servo and need to upgrade but I have removed the pan for now as it was also imparting general instability (jitters in all axis).
