Please do be carfull when powering your Skyline gyros - although the input voltage is 4.8 - 7.2 vots. 7.2v is the maximum and not a nominal voltage. Do not try and power it with a 2S you will blow it. In future revision we will look at changin this.
Cople of tips when setting up the Skyline:
Make sure the gyro is as level as you can get it when you set it up for the first time - also keep an eye on it to make sure it does not move, you will get better results
A 6v or 6.5v 5A is more than enough power to get the speed and smothnest out of the Savox servo. I know some of you use a 2S power supply to try and get better preformace out of the MK flight controler when used for gimbal stabilisation. It is not required with the Skyline!
Please log in to our web site you will be able to down load the Software and firmware from there. We will upload the instruction manual on Monday we are just finishing it off.
Thank you,
Kimberley Attwell
