Any help please with settings for dji F450 and mx-20
salzpro
I've just bought 'dji F450'(Hobby) and remote control 'mx-20'(Graupner). Trying to find any information in internet about settings for dji f450 and mx-20 and no result... The problem is how to assign GR-24 Graupner(Receiver) and dji F450 Main Controller(MC) and how to assign remote control with receiver....Is it possible to find a file(to load it) with all settings for dji f450 with mx-20??? ;-(
Hallo Salzpro,
were exactly is the problem ? Connect you receiver the MC and check in the DJI config screen of the TX if you can see the slider move !
If you want to and you feel more comfortable i can also help you in german via email.
boooyv
DJI Setup Help
Anyone, please help!
I am trying to set up DJI Wookong H Lite. Everything was looking good. I went though all wizard steps on the DJI Wookong H Assistant Software and result was ok. Then, I flew the helicopter in manual mode. Everything was fine. After that, I switched to atti. mode and tried to fly it again. Everything was looking good again including single green flash light, indicating the system was ok. But, motor was not working at all. It was still working well as normal when I switched back to manual mode. My question is why did motor is not working in atti, mode? Thank you in advance.
Boooyv, I just set up my T550 with the WKH GPS. What is your set up? ESC, etc. Are you running with a governor or using the recommended throttle curve. The other question is your mode switch set up correctly moving to highlight ATTI? Pictures really help.
