roycruse
Hi guys
Im looking at eCalc and wondering if it has any meaning in the real world.
It doesnt seem to have a setting to choose between a Hexa and a Y6 or an Octo ands an X8
Im not sure the same calculations make sense when mounting motors side by side and one above the other.
In an X8 or a Y6 the under over motors will be assisting each other - the top prop supplying moving and pressurised airflow to the bottom prop and the bottom prop in turn providing a low pressure void below the top prop.
So does all the calculations go out the window in Y6 and X8 configurations.
I have finally got a couple of motors and speed controllers arrived in the post today and will start taking some real world readings tonight but I was just interested in seasoned multi rotor builders/flyers opinions of this software.
This is the kind of thing I'm hoping to build as an Aerial Photography / Videography platform to carry a Canon550D and 24mm wide angle prime lens... (total weight of camera = about 800g)
http://www.ecalc.ch/xcoptercalc_e.htm?ecalc&weight=3500&rotornumber=6&elevation=500&airtemp=25&batteries=lipo_2100mah_-_20/30c&s=3&p=4&chargestate=normal&esc=max_30a&motor=turnigy&type=sk2836-11&propeller=apc_electric_e&diameter=13&pitch=6.5&blades=2
