Hi,
I am new to the forum and to quads but am fairly experienced with electronics. I have a x700 homebuilt quad which originally used post feb 2014 turnigy multistar 30A ESCs. These flew ok but felt laggy (might have been me but I like to try to improve things). I attempted to flash one with SimonK and caused it to immediately catch fire and explode when I tried to test it. (I don't think the new ones like SimonK, I did read the thread on it, and I did try to flash the modified one for it, not sure kkflashtool chose it properly though). I then bought 30A AfroESCs and now it won't even take off, I haven't changed anything else on the quad except reinforcing the crab and I can't believe that an extra 30g would affect a quad which on paper should be capable of lifting 2kg with each rotor, and would previously take off at just under half throttle.
The specs on my quad are:
X700
Turnigy multistar 690kV outrunners
12x4.5 props
KK 2.1.5 running 1.6++ KapteinKuk firmware (I have also tried the Steveis 1.18 pro)
6600 mAh 4S 60-120C(yes it is massive, and yes I know it is not really designed for a quad)
FrSky V8FR-II receiver
Turnigy 9XR pro transmitter with DJT module
I will attempt to answer any other questions you might have if someone can tell me what I have done wrong. Thank you for your time.
X700
12x4.5 props
