Dx7 and naza v2 mix settings beginner
S5baby
Hi guys new on here so take it easy I have just purchased a dji 450 e300 with naza v2 and I am having problems on getting the switches to control the different modes and the fail safe I'm just getting into quadcopters and have only had a dji phantom before this so I am finding it very tricky so any help would be more than appreciated thanks Alan also the tx is a standard dx7 not dx7s
Benjamin Kenobi
Easy? You call that easy?
Hi Alan, welcome to the forum!
So, where to begin. Learning how to program the DX7 will be you first hurdle. Without going into too much detail, you will essentially need to adjust the D/R or servo travel to adjust the various settings. To do this, connect the NAZA to the assistant program (computer/USB). You will find some sliders in there probably under the RC section. These sliders show you what your switches are doing.
At first you will look at everything blindly and adjust stuff to see what happens. This is normal and we all went through it so don't worry if nothing makes sense at first.
There are plenty of online videos to show you the setup. Don't worry if they are for different Spektrum transmitters, they all basically work the same.
Please do ask more specific questions as you go along.
Regarding the modes. What receiver are you using? You'll want the U port on the NAZA connected to one of the spare channels on the receiver. In my case I have it connected to the gear channel which is activated by the 3 position switch on my transmitter. I connected (programmed) the gear channel to the three position switch by starting the transmitter whilst holding down the menu button so it goes into the programming mode and selecting channel/servo setup (something like that!), then adjust the setting for GEAR to be activated by said 3 position switch.
I know, that makes no sense. But keep at it and it will! :nevreness:
S5baby
Thanks for that and yes it doesn't make sense at the moment I am using ar8000 with the dx7 I just can't figure out how I even get the 3 position switch to do anything I have been on you tube and there is a guy but he has a dx7s but he has settings I can't find on mine I will get there in the end I have even called the local hobby shops who just don't want to know or want to send it away which I'm not to keen on
