SurreyMike
I have just finished building a Jakub's frame small Tri copter with a Mutiwii board installed. The issue I can't deem to resolve is that as the throttle increases you get to a point were the whole thing flips violently onto its back. I've hooked it up to the GUI and everything looks OK. At first it was spinning on the spot reversed the yaw and that seems to have taken care of that. Have tried compensating with trim but it just don't want to get off the ground.
If I hold the copter and move it from side to side it seems OK but as its such a small unit its sometimes difficult to know what its doing as when you tilt it you can get some wild movement.
I'm using a Spektrum DX7 on acro with no mixing etc. etc. and having tried just about everything imaginable I'm stuck for ideas. Any suggestions would be much appreciated.
Regards
Mike
Regards
Mike
