LeeT
Wannabe AP Dude
I just finished changing motors and batteries on my hex. I went from T-motor 2216-900 on 3S to KDE 2814-515 on 4S. The hex lifts off around 70% stick throttle and after a few second it then accelerates upward. When I give it any stick it will rock back and forth violently. It is also listing to the left. The hex is well balanced and COG is as close to center as I can get it. I did reduce the gains from 140, 140, 100, 140, 110, 110 to 120, 120, 100, 120, 100,100 which helped a little with bucking. I have a hard time holding it in a hover as it either wants to accelerate and go up or slow down and come down. Throttle response is very slow. I have the throttle start set to recommend.
It flew fine the last week before I changed out the motors.
The props are 12 X 4.5.
My guess is one or more of the ESCs are on the fritz. As I solder the motor wire directly to ESC it is possible I could have damaged one of them. Four of the ESCs were warm to the touch after a very short flight of less than 2 minutes.
The motors spin up as expected without the propellers on.
Thoughts?
Thanks.
Thoughts?
Thanks.
