Wookong-M motors not Arming but NAZA V2 on same frame works
kleslietx
Hello all please help,
I have a Wookong-M that I would like to put on a Y-6 frame. However, I cannot get the motors to arm. I can test each motor using the bluetooth interface just fine but when I try to arm in any mode, GPS, Attd. or Manual, I get nothing. Now here is the kicker, I have a Naza-V2 that I put on the same setup and it works without fail.
I did attach to the computer just to check firmware and to see if I had channels reversed and all seemed ok. But reloaded the firmware yesterday just to be sure.
Please see the video....
https://copy.com/9wi76UZu0oZGPPzb
T-Motor MN3510-25
ESC ZTW Spider 40A OPTO w/SimonK
thanks in advance
Benjamin Kenobi
Easy? You call that easy?
Er, there's no quick checking the assistant. Go through it slowly and properly. The important bit: Which transmitter are you using? Calibrated it yet?
kleslietx
I'm using the same transmitter. Also, I went through throttle calibration again yesterday for each ESC. I have in the pass been able to switch between NAZA & WKM leaving everything else in place without any issues.
Benjamin Kenobi
And which transmitter is that? I meant the transmitter calibration in the assistant software rather than ESC calibration.
