Balmybaldwin
Only taking my first steps with mr flying, so still getting used to lipos and flight times.
Went out just now to have a quick flight, and after about 8 minutes, whilst in atti mode, the power suddenly reduced (landed gently though). My voltage alarm (set for 9.3v) hadnt gone off, and the battery had 11.2v on the meter the battery wasnt warm to the touch (neither was anything else).
Whilst the throttle did work, it wouldnt power up enough to take off. This was the same if I switched to gps mode. However in manual mode, I still had full control over the power and could take off and hover normally.
When this happened in atti or gps modes, the little led on the naza was flashing orange iirc. When I got back home, I checked the naza assistant, and I noticed that the voltage protection switch was on, and the first level protection was set to 11.5v and second level to 11.1v
Am I right in thinking that the protection level 2 triggered? If so, these voltages seem a bit on the safe side? How much lower should I go (running 3s lipos) and how much higher should I set my alarm so it goes off first?
