Vortex
I'm having some problems setting up a MK system and having no previous MK experience and I need help.
I have posted both these problems up on the MK forums and that's pretty much a waste of time so I'm hoping someone here can help.
My set up....
MK FC2.5 Ver2.02b
Motor safety switch Ch8 + gas 0
no start without GPS fix OFF
Servo endpoints set and working
Config OctoX-XL
Tx Graupner MC-20
I am having trouble getting the motors to start.......Throttle to 0 and flick the start switch and the unit beeps and I get the message "Minimum Speed"
lastnight I did get it to start and the switch worked fine but after I switched the Tx off and unplugged the battery and re started it, I could not get it to start again and was right back where I started.
The other problem is in the mixer setup, I have it all set up correctly and the motors run fine in the motor test. When I open up 3D and check the orientation of the copter the heading is in the + configuration and not X. When I rotate the orientation line and check in 3D it has not changed and is still heading as it was before.......It's almost as if it is not changing anything. Is this right or am I missing something??
Thanks and hope someone can help.
Regards,
Lance
My set up....
MK FC2.5 Ver2.02b
Config OctoX-XL
Tx Graupner MC-20
Regards,
Lance
