I am trying to set u my M-Lite, using a Turnigy 9XR and Orange DSM2 Tx and Rx moules. I have installed the Naza Assistant software (v1.0) and it recognizes the LED unit.
I then get an error msg, which varies from "Rx Error" and sometimes "CFG error". When I disconnect the USB I get bright orange flashing.
This apparently indicates Fail Safe, but this is not the case (I think) because the TX and RX work well when used normally. I have tried various "Bindings" on FailSafe but nothing appears to work.
I have connected TAER and U on the first 5 channels (Mode 2) and from the naza connections to 4 motors.
Should I "Bind" when all of these are connected up?? This is the only thing I haven't tried, though i din't see how this can work as the TX has to be switched on first ( When Binding the TX is switched on second).
Any advice would be greatly appreciated.
