Computer not seeing IOSD Mini . What am I doing wrong?
38super
HI ALL
I finally got my IOSD working great after a wiring problem was solved. As per instructions I down loaded IOSD Assistant with no problem. But my computer does not see it and have no idea why. First question is about the driver . Is the driver I use for naza assistant the same as for running the IOSD assistant? When I plug in USB cable in I get that tone from Windows 7 telling me it found driver. IOSD is blinking green telling me it is getting data, Computer see's naza just fine when I plug into MC, LED.
I did see something about having a dll or something in program/dji/drivers and downloaded it but found it was already there other then that I found nothing on line about this.
This the only thing keeping me from giving it a try (IOSD) Has anyone else had this problem?
Will
All firmware up to date and did down load driver installer .
38super
Yes I did . I just went to try again and saw on IOSD Assistant light on bottom is green with blinking blue so it is getting through I just can"t get a real time display . It tell's me to display real time
Is there a button or something I have to activate or does it just display itself when you open software. Just seems like some little thing I'm not doing I have ID # and all
If I understand you correctly, you are expecting to see your camera output in the software? The software does not do this, all the software is for is to set warnings and upgrade the firmware. I wish you could also modify settings like change meters into feet and so on. I really wish DJI would make this change, I do know a lot of people have requested this.
