jfro
Aerial Fun
Contemplating building a hex or x8 in the 850-900mm range with AUW of 16-20lbs. Most likely using 3515 400kv or similar sized motors w/ 14" or 15" props.
I'd like to get opinions on pro's and cons of what make a stong frame with the least amount of potential vibrations as far as the construction of the arms go.
On my current x8 with 21.5mm arms, I have had to spend a fair amount of time leveling the motors on the round arms. If I overtighten them, the ends of the tubes will crush/ crack. Consequently it seems to me that the rectangle arm, either carbon or aluminum would be easier to keep the motors level.
As to strength, I have no idea what is stronger.
Thanks in advance for any advice.
