mbsteed
aerial video centric
Anyone tried these ESCs?
http://www.castlecreations.com/products/quadpack.html
How would those work with WKM?
No idea about these new ones but in my case ice50, ice50 lite and edge50 runs very hot with 6S and 10-15A average only per esc. 85°C is a common temp recorded at 25°C outdoors and thats double of what I got from an herkules III with the same equipment and conditions. There fore for me it is not an option until CC found what makes their ESCs run so hot and correct it. Refresh them with airflow is not a solution, the only masks the problem and the herkules III is as fine or as bad refreshed as the CC on each equipment I tested. Have a customer with one CC ICE50 completely burnt and that was because CC has to close running temp to their max allowed.
What ESCs would you suggest for an octo HL (lifting a Canon T2i & 3 axis gimbal) with Axi 2814/22 motors? I want to replace my current ESC setup (Maytech) and eliminate ESC issues as a possible cause to a wobble I get (adjusting the gains has no affect on the wobble).
No issues at all for over a year with my Ice50. Only running them on 4S with MT2814. Performance is much better than simonk flashed junk esc.
Some other good options are the Ultraesc and the Herk III. All 3 esc have performed flawless for me for many months.
Cheap esc's and lipos is one of the main reasons multis fail.
.............Bart, did you flash those Hobbywing with SimonK code? I do have the adapters to do the flashy thing now but just haven't tried it yet.
